Powerline priority?
Posted by: thijazi on 06 February 2016
I have a NAC282, SuperCap.DR, DAC-V1, NAPSC and a NAP250.DR system and just got 2 Powerlines on demo to try out. What would you suggest could be the best approach in order of priority to start? eventually I figure I will have all four units (DAC, NAP, NAPSC and SC) on PLs, just not sure in which order, any thoughts?
Posted on: 06 February 2016 by The Strat (Fender)
Worth experimenting but I'd start with the SC and 250.
Posted on: 06 February 2016 by analogmusic
Pl on the SC and DACV1
or forget the PL and just get a 252 instead
Posted on: 06 February 2016 by trickydickie
I'd be investigating source upgrades first
Posted on: 06 February 2016 by Gavin L
Interesting question, I have quite a different setup (555/552/SNAXO/500/300/500) and one Power Line, the rest are powered by a "spider" from Grahams.  I recently moved the PL from the 552 to the SNAXO.  Initially I thought it made a notable difference, but now I am not so sure.  I would be interested to hear the experience of others.
Posted on: 06 February 2016 by MDS
I would, and did, start with the Napsc on the 282.  It gave me a very noticeable and worthwhile performance improvement. The second I'd put on the Supercap.
Posted on: 06 February 2016 by Steve J
Ordinarily I'd say you should go with the source first and you should try one with the DAC-V1 and SC but I think you may hear the best difference with the SC and NAP.  It's easy enough to try both combinations.
Posted on: 06 February 2016 by sheffieldgraham
thijazi posted:
I have a Powerigel 8 +1 Powerline. Separate sockets on a double unswitched MK dedicated spur socket.
As per Dark Bear's  suggestion put the Powerline on the power amp (300) from the 552 psu.
Not a night and day improvement, but left it in place ( better cable dressing).
Personal experimentation is the only way.
If you're going to fit all four does it really matter?
1. Nap250.DR
2. SuperCap/282
3. DAC-V1
4. NAPSC
Posted on: 06 February 2016 by TOBYJUG
Put it on the kettle and the tv..  Have a nice cup of tea whilst watching Eastenders .
Posted on: 06 February 2016 by nigelb
That is going to be one helluva cuppa!
I didn't like the power line in the dac v1 and new firmware
sounds better to me without power-line
with the older firmware the power line improved the dac v1
Posted on: 06 February 2016 by feeling_zen
Generally I think a HiLine on the source is required to let PowerLines really shine when added to the system. If only 2 then definately I would put those to the SC and 250. If you had a better source I may be inclined to move the PL from the 250 to the source (such as an nDac or NDX).
I know there are many advocates of putting the PL on the NAPSC. I must be honest and say when I tried it I heard no difference. The NAPSC doesn't power any signal carrying circuits so I wasn't surprised but wanted to test anyway.
Posted on: 06 February 2016 by thijazi
Lots of good feedback here, will start with the 250 and SC then try to locate a third PL and hook it up to the DAC to complete the setup. The HiLine is what I suppose would replace the standard Naim cable connecting the DAC-V1 to NAC282 (I wish there was a guide to the Naim naming conventions ) so this would be the next quest for audio nirvana.
Thanks all for your feedback.
Cheers..
