Album Art missing in album view in naim app
Posted by: David on 07 February 2016
Hi
I have an issue with album art not being visible for some albums in the album view. The art shows if you select an album, and in the playing view, just not in the album view where you see the thumbnails. A folder symbol is displayed as if there were no album art file.
Looking at the jpeg files I can see that the ones which are not visible have a higher pixel density that those which are visible.
Are there recommended specs for the album art files for the naim app or is this a feature of the media server (ReadyNAS built in server)
Any my info/advice appreciated.
