Hicap DR or NAP 200DR question?.
Posted by: Pieman. on 14 February 2016
Hi Forum.
I am thinking about uplifting my 2008 Hicap to the later DR spec  , but wonder would the improvement be any different to changing the NAP 200 to DR spec without using a Hicap at all. I believe only the preamp benefit's, to the DR change on NAP 200 DR. The preamplifier is a Nac 202 with Napsc.
Regard's
Pieman.
Posted on: 14 February 2016 by Antonio1
No
upgrading your 200 to DR and not using any Hicap- either DR or not -on your 202 won't match the goodness you would get with the hicapped 202/ NAP200
Posted on: 14 February 2016 by Pieman.
Hi Antonio1.
That is what I thought would hopefully be the case.
I will look to upgrade the Hicap to the DR spec in time, to give the NAC 202 a better power supply .
Regard's
Pieman.
Apart of the upgrade
Is it undergoing a full service?
That's important to know
Hi,
I am thinking of having a service at the  carried out at the same time. This hopefully would cost a bit less than sending the Hicap away again at a later date.
