New day new problem
Posted by: Belfast Taxman on 17 February 2016
Well that is how it seems. First the good news, the 272 has not muted itself today, however it simply refuses to talk to the Naim app. I have tried deleting and reloading the app but nothing is happening.  The 272 is definitely connected to the same IP address and I can access Spotifyand Tidal via Bluetooth,  but when I retry the Naim app route zilch. Any suggestions
Posted on: 17 February 2016 by Timjoebill
Try rebooting the wifi router. Sounds obvious, but has worked for me in the past.
Posted on: 17 February 2016 by Belfast Taxman
Thank you it appears to have solved the problem. What confused me was that the 272 was telling me it was connected to the wifi and that Bluetooth was working.
Posted on: 17 February 2016 by Benny
I found this post from the featured topics very useful.
Spotify, AirPlay, App and UPnP Discovery issues...
Posted on: 17 February 2016 by David Hendon
Yes I was about to suggest rebooting the router when I saw timjoebill's reply. In my experience there is almost no situation where reinstalling the Naim app is necessary. The Naim app is very stable now and the 272 is too, so the issue is almost always a networking issue. Rebooting the router is one fix to try and a more long term fix is to put a cheap switch like a GS105, to which you connect everything and just have one cable back to the router. That change sorted out my occasional networking issues in one go.
Going back to your muting problem, if you are still running the firmware which was in the 272 when it was delivered from the factory, then I think the suggestion someone made of a faulty logo/mute switch is worth following up. If someone has done a firmware update on the 272, then it could be worth resetting the 272 to factory settings because the firmware updates mostly don't do this and Naim recommend a factory reset.  Occasionally odd and inexplicable issues get reported in the forum which get sorted by a factory reset.
Good luck.
best
