To Hum or Not To Hum 72/140
Posted by: Shane on 17 February 2016
For many years 1995 not a hum with both side by side mm apart, then bad Humming in speakers (Naim Intro's) in 2015 only occasionally switched off over the 20 years. Now both serviced humming worse then ever when m/c phono selected, the two interacted and amplifies it. A call established its a common problem (Forum proves that). Well the out come is keep the two apart as far as space will allow, mine are 1'1/2" ft has eliminated problem. The new addition is a HiCap (Olive) which now sits next to 140 and greatly improves performance all warmed up and running in nicely.   Hope this helps the fix is cheap so give it a try before spending cash.
Shane.
Posted on: 17 February 2016 by varyat
Glad it worked out for you..
