Where does the source first principle turn into the need for a new pre amp
Posted by: Pawson6844 on 18 February 2016
I feel as though I've hit a bit of a crossroads at the moment. I've just taken advantage of the Linn offer with their new cartridge and discount off another product to upgrade my LP12 to akurate spec.
Recently just added a hi line to the cd5 xs flatcap xs side.
Dealer has offered both a cdx2 and ndx  for home demo. He favours ndx and has recommended I change to the streaming route.
I would say currently we use vinyl as much as CDs.
I keep reading peoples thoughts on not making too many smaller steps and save for one big one. The next upgrade will be it for some time so want to get it right.
Do I change to an ndx now with the Lp12 upgrade and keep the 202 hi cap dr for a while, do I keep the cd5xs set up and get a 282 then maybe save and look for a used/ex dem nds down the line and skip ndx out altogether?
Seems like so many options from where I am now. Any opinions where's best to start with some home demos would be great. All equipment on fraim.
Posted on: 18 February 2016 by cdboy
Just yesterday I sold my last ever Naim CD player (CDS3) having owned different models since 1995. Streaming is definitely the way to go if you are comfortable with the technology. As to which streamer. As always you get what you pay for. I love my NDX (with XPS DR) but do now wish I had bought the NDS which I know I will move to one day.
Posted on: 18 February 2016 by naim_nymph
You'll get lots of opinions on how to spend you money but my advice is;
exploit the upgraded LP12 by buying the best [2nd hand?] pre you can afford, 282 or 252.
Either will sit happier with your 250DR and will sound wonderful compared to a 202
Posted on: 18 February 2016 by CharlieP
Since vinyl is your primary source, and you may want an NDS (or whatever is next in the pipeline) someday, You may get the most from your LP12 and 250DR by replacing the 202 with a 282.  Limp along with the CD5XS/FlatcapXS for a while, then upgrade the digital source down the road.  Perhaps the CD5XS and FlatcapXS could be traded for a nDAC, DAC V1 (or other in the pipeline - perhaps some one will suggest another DAC) which you could use with a computer to play ripped CD's.  My 2 cents.
Charlie
Posted on: 18 February 2016 by Erich
Try to get the most of your LP12. I also have an Akurate level LP12, 252, 250DR and I'm very happy with the kit.
If you have the opportunity to try 272 with 250DR do it, it's a way to get into streaming, maintaining you CDP while you rip your CDs. Some members are very happy with 272+250DR. May be somebody can provide feedback regarding lp12 going into this kit.
Regards.  Erich
Posted on: 18 February 2016 by DavidDever
You'll likely find, with decent rips, that an NDX should outperform the CD5 XS pretty easily. Definitely visit your retailer, though, to decide for yourself; the 202 with a Hicap 2 DR should be plenty wide open enough to show the difference.
Posted on: 18 February 2016 by Allante93
Just some information that might be helpful on deciding what to demo!
Classic Naim Preamplifiers  USD 2015-2016 Price List
NAC 552 Reference Analog Pre-amplifier $34,995
NAC 252 Classic Series Analog Pre-amplifier $11,995
SUPERCAP-DR Classic Series Power Supply $7,695
NAC 252 Total $19,690
NAC 282 Classic Series Analog Pre-amplifier $7,995
NAC 282 w/sc dr Total $15,690
Preamplifiers w Network capability
NAC– N272 Pre-amp with Integrated Streamer $5,995
XPS-DR Classic Series Power Supply for Digital $6,595
The reason the 282 is so popular is because it gets into the conversation, @ 3K 2nd Hand, and can be used as an Analog Hub, supporting, LP 12’s, Ndac’s,  US uniti’s, etc… and bare Cdx2’s.
Flexibility can't be overlooked either, the 552 & 252 are only function with one PS, while the 282, can function with a HC, 2 HC's, HCDR, and a SCDR. Phono RCA inputs, BNC, etc.... Maybe not Naims best Pre Amp, but so close it really won't matter, until you run across a 2nd hand 552!!!!!!
In the mean time, one can enjoy the analog TT, and multiple digital Sources all with a 2nd hand NAC 282!
The Armchair QB!!!!
Posted on: 18 February 2016 by Bert Schurink
naim_nymph posted:
Would echo this. Your LP12 is to good for your 202. So at least make sure you move up to 282 or 252 and then consider potentially to upgrade your 2nd source.
Posted on: 19 February 2016 by yeti42
Another vote for the 282.
Incidently (in case you're considering playing with one) I had a single powerline for a while and prefered it on the CD5x rather than the FC2x, hicap or 250 using that pre, there is a case for using it on the PSC instead but I didn't try that while I had the CD5x.
Posted on: 19 February 2016 by The Strat (Fender)
You have a high end NAP but more mid-range pre.  I would go in he order of:
282
NDS/XPS.
Posted on: 19 February 2016 by Pawson6844
Thanks for the replies. Strong opinions for the 282. I won't be able to get 282 and a ndx at the moment even if I buy used. It's one or the other really.
If I do go 282 route to match the lp12 level will I notice any improvement on the cd side over the 202? Or are we now at a level of pre amp that the cd side is giving everything it's got?
Posted on: 19 February 2016 by hungryhalibut
As well as trying the NDX and the 282, do try a 272/XPSDR. The NDX//XPS/282 may be a bit better, but you are looking at a two box source and a four box amp, whereas the 272 option has three boxes and costs a lot less. I'm very happy with mine: it's small, simple and neat and yet sounds really good. It may or may not be enough for you, but it's well worth a try. And, as has been suggested above, you could keep your CD player as a temporary measure.
I don't think the 272 is for us at this moment. Everyone in the family uses the Hifi so it's not a once a month hobby, it gets used daily so I can definitely see us progressing further up the chain over the coming years as funds allow.
I will eventually get a separate streamer no doubt.
The mrs even likes the look of fraim and is requesting another stack to fill the void at the side of our fireplace. Win win I think!
In which case, I'd go for the 282. It's miles better than the 202 and will benefit your LP12 and the CD player too. The 5 series players, particularly with the Flatcap in place, are really very good.
Posted on: 19 February 2016 by count.d
Paws, the standard answer on this forum is to go straight to the 552 and stop messing about. They are a vey helpful bunch and looking out for your best interest.
552 is a dream at the moment. Unless the lottery comes up. Fingers crossed.
I think a home dem of a 282 is in order. A few on the second hand market at tasty prices too. I'm presuming newer the better to take advantage of latest technology. Has the 282 actually been updated at any point?
The 282 has never formally been updated. I think it's usual practice to change the various components as suppliers change etc, but a 282 is basically a 282.
Paws, the 552 is dream for most people and you'd be better off upgrading the source first anyway.
The 282 is Naim's worst value for money product. Upgrade your source.
Hungryhalibut posted:
Is it just the naps that have had the dr treatment. Nothing on preamps? Basically a 2010 282 would match a 2015 282 allowing for the older models needing a service sooner.
Posted on: 19 February 2016 by T38.45
I have no pre- amp:-) straight out my DAC to NAP250DR....and it sounds sublime (even my dealer was "wow" )
Yes, they are basically exactly the same. The DR change was first done to the power supplies, including the Hicap, and last year was done to the bigger power amps.
T38.45 posted:
Presumably your DAC has a volume control then?
Posted on: 19 February 2016 by GraemeH
Having just gone SN2-202 to 282 I'd say 282 every day of the week - and twice on Sundays.
Posted on: 19 February 2016 by james n
GraemeH posted:
I thought you'd given up all the boxes - didn't you originally have a 252/300 . What happened ?
Posted on: 19 February 2016 by dayjay
The Strat (Fender) posted:
T38.45 posted:
It will be bloody loud otherwise!
T38.45 posted:
Yes, volume and remote
