To bass or not to bass - Ovators S-400
Posted by: Adam Zielinski on 07 March 2016
Dear Forumites,
Some thoughts and observations on my two systems (details are in my profile).
Recently noticed that:
Of course the two rooms are different in size and their acoustics are different as well.
The question is: am I hearing a pecularity of my rooms or the Ovators (less bass fundamentals)?
Posted on: 07 March 2016 by GraemeH
Very difficult to say without swapping the loudspeakers room to room. I found the SN2 struggled a bit with the revealing nature of the S400 hence the move to 282/HCDR 200.
The bass with the latter is plentiful, tuneful and beautifully integrated.
Posted on: 07 March 2016 by hungryhalibut
Or swapping the amplifiers...
Posted on: 07 March 2016 by Ken Ploegaerts
SN2 or 282/HCDR/250. Not a fair fight...
Room interaction is soooo unpredictable. S600 sounded really poor in the same room and position that allows the S400 to sound superb.
Posted on: 07 March 2016 by Adam Zielinski
I will move the Ovators over the weekend, but since their Wife-Acceptance-Factor is virtually non-existent, they will most likely end up in the music room anyway
Posted on: 07 March 2016 by James L
S-400's are light on bass. Or should I say they don't extend. You are hearing them correctly.
James L posted:
Not in my room.
Posted on: 07 March 2016 by joerand
Hungryhalibut posted:
I agree with HH - the true test here is swapping the amps and keeping the speakers as the constant in the room. Swapping speakers is the lazy man's way out, though might provide some lateral insight. That said, I wouldn't consider some tweaking of the speaker position (once the amps are switched) as cheating .
Posted on: 08 March 2016 by Adam Zielinski
Will do some tests - various options - over the course of this week and will revert with findings.
Adam
Posted on: 08 March 2016 by Hook
GraemeH posted:
James L posted:
Not in my room.
Everyone has a different idea of what constitutes "good bass".  The 400's are -3dB at 36Hz, so subsonics will not be there. Also, if room geometry is creating peaks and nulls in the mid-bass, any speaker can sound wrong.  It's always been a case of YMMV...
Like Graeme, I got lucky with the 400s in my room. The output from the twin bass drivers is punchy, dynamic and very clear. On even my oldest jazz recordings, the standing bass notes are easy to follow. My trousers may not flap with modern electronica, but I don't feel that I am missing much in terms of musical communication.
ATB.
Hook
That's actually a very good description of Ovators that Hook just posted - they are very clear and punchy.
Posted on: 08 March 2016 by Dan43
I found S400s very tight and punchy on the bass, but little excitement overall in the end. For me they performed at their best with higher frequencies especially when upgrading the front end, vocals especially sounded tremendous.
Posted on: 08 March 2016 by GraemeH
I'm unsure as to why the S600 (300 252) produced 'less' bass (by quite a margin) than the S400 (200 282) when positioned in the same spot in the same room...There must be science behind an explanation.
Frank F posted:
Adam, if you need bass listen to Linn Isobariks or Saras.  I have a pair of Saras in Warsaw driven by 72/HC/250.  I also sometimes use Quad ESL63s for total lack of colouration!!  Either way the bass is clear and extended.  We will be in Waw later in the year if you want to listen?
FF
Frank - with pleasure. Drop me a line (email is in my profile) when you start planning your trip to Warsaw.
Adam
Posted on: 08 March 2016 by MDS
GraemeH posted:
One factor might be the 282.  I've twice found it seems to give a (pleasing to me) emphasis to the bass as compared to the 252. Not suggesting this characteristic is accurate but to my ears it is more enjoyable and fun.
Mike
MDS posted:
GraemeH posted:
Mike
Thanks Mike.
Posted on: 11 March 2016 by Adam Zielinski
A short update.
Speakers were out of phase!
Traced it to incorrectly assembled NACA5 cables (got them 2 weeks ago) - one of the cables had black and red plugs (a speaker end) swapped around. Grrrr...!!!!
Also took the time to re-dress the system with Power Lines. Sounds like black velvet now (if velvet could actually emit sound, that is ).
Smile is back.
Posted on: 11 March 2016 by GraemeH
Adam Zielinski posted:
A short update.
Smile is back.
Excellent Adam!
Posted on: 11 March 2016 by Loki
Adam, are you going to swap the speakers/amps just for the sake of form?
Posted on: 12 March 2016 by Adam Zielinski
Of course.
Must test this option as well.
