Should I go NDX or DAC
Posted by: Richwleeds on 10 June 2011
I am about to order a streaming solution for my main Hifi (552, 2 * 300, active SBL). I am torn between a DAC or NDX. It would work alongside my LP12 and CD555
All my digital sources are in ITunes (mainly lossless), I have an apple network and use a combination of Apple TV and Airport Express to stream music to other systems in the house. My itunes library is housed in a 2TB hard drive attached to my Apple Airport Extreme router (effectively I think acting as a NAS). I cannot get a wired connection to the hi-fi room so any solution would have to be wireless.
I listen to the i-Tunes library, Spotify and internet radio via Airplay and if I need to stream other sources (e.g. football commentary from Leeds United's web service) I use Airfoil to push out the the audio signal.
If I go DAC I would stream to an Apple TV and then feed its digital signal to the DAC and use an Ipod touch as a supplementary source. I know that would work great and enable me to use airplay for Spotify and internet radio, and airfoil for non airplay sources
Before I order the DAC I have been thinking about NDX as a more integrated solution - but could anyone advise the advantages / disadvantages of the NDX option instead of the DAC for my setup - I guess the main things I am concerned about are compatibility to Apple (happy to convert files if necessary), whether I would lose Spotify & Airplay and whether an NDX option would still allow me to use Airplay / ATV/ AEs for the rest of the house.
Many thanks - Richard
