HDX internet access via NAS with WiFi dongle?
Posted by: Ollix2 on 10 June 2011
Hi,
does anybody know if it's possible to connect a HDX directly via wired ethernet to a NAS (say QNAP TS-110) and then give the HDX internet access by putting a Wifi dongle into the NAS which connects it wirelessly to the router?
I know this is an unusual setup but that would be the best way for me to keep my normal mains seperated from my dedicated spur and at the same time have a hard wired connection between HDX and NAS.
Thanks,
Oliver
Hi David, you mean a second router (in bridge mode) additionally to the NAS? Yes, I know that would work but than I'd have two SMPS on my Hifi power bar. For sonic reasons I want to put as few as possible SMPS on it.
You could change all your SMPS with Linear PSU's!
aleg
Hi Aleg, which ones would you recommend for that purpose?
I'm not allowed to say, I'll get my postings removed when I do.
You can send me an email at M8R-p4w13v@mailinator.com
Yes, but not ambitious enough to do it without help. Maybe you or some other network expert could elaborate this a bit more. Thanks!
Qnap supports wireless dongles, though I have not tried it
Yes, there's a compatibility list for Wifi dongles on QNAP's website. My problem is how to tell the NAS that requests for external (internet) IP adresses by the HDX are passed through via Wifi dongle to the router. As far as I have understood, the problem has something to do with different subnets (HDX<->NAS and NAS/Wifi-Dongle<->Router). I was hoping that there is some kind of plugin to give the NAS routing functionality. I think I'll have to consult an IT specialist.
@ David: Thanks for your help! Regarding SMPS I have a slightly different opinion. I can hear a clear worsening if I put a (cheap) SMPS on my Hifi bar. Top end gets thinner and harsher, sibilants are more emphasized. AFAIK Naim has put a filter in front of the u-Serve SMPS to prevent noise injection into the power bar. So I think we shouldn't neglect pollution caused by SMPS.
Use a linear DC supply for the router–sorted.
