NDX not reading converted files
Posted by: Woods Scot on 12 June 2011
I had a number of files that were in apple lossless (mp4a) format. These are obviously not read by the NDX. I have since converted all these files, using a utility called "switch" (as I have long since stopped using iTunes). These files were converted to .wav, but are still not being recognized/played by the NDX. Any suggestions?
Scot
Posted on: 12 June 2011 by Sloop John B
Does the NDX see wav files not converted by switch (to rule out a "switch£ glitch)
When I tried wav files with my Uniqute the artist name, song, genre etc.  tags wer not kept very well so could it be that they are in a particular folder which you can find but the tags are not being picked up?
SJB
Posted on: 12 June 2011 by garyi
Its likely the tags did not come over with the 'switch'
Posted on: 13 June 2011 by Woods Scot
Strangely, I have gone through a number of the files and re-tagged them, with no success. Other flac and wav files work fine. All my conversions have issues This is becoming a little frustrating Scot
Posted on: 13 June 2011 by Hook
Scot -
Can you try another conversion tool (e.g., MAX from sbooth.org)?
Good luck.
Hook
