This morning my Uniti Serve has been skipping like a CD player, replaying the same 5 seconds over and over, then crashing (not responding to commands).
Is there a solution to this problem?
Posted on: 19 June 2011 by Chris Bell
Yes, twice. Second time seemed to do the trick... playing now.
Because this is a Windows device, does it require any service packs or virus protection? It is connected to the internet.
Posted on: 19 June 2011 by Klout10
Make sure you have the latest software installed, overall version should be: 1.5a SP2
I'm not aware how Naim deals with viruses on these machines ...
Michel
