Minimserver
Posted by: Robert Daoust on 10 March 2016
Does anyone know how to get Minimserver onto my QNAP NAS? The Minimserver instructions say to go to App Centre, but my file structure on the NAS doesn't contain this. I had TwonkyMedia installed at the outset, but I don't see where that lives, either
Posted on: 10 March 2016 by Harry
Are you going through the QNAP's web interface? It's the NAS's IP address typed into a browser.
From here you can install apps such as Minimserver using downloaded files, stored at locations you specify, such as your PC HDD.
If your QNAP runs an ARM processor you will need to install a JRTE (Java Run Time Environment) update first. You can skip this if your QNAP runs on an Intel processor. The Minimserver online help pages are clear and comprehensive.
All the best with it.
Posted on: 11 March 2016 by gert
When checking the live demo of qnap I see an icon "App Center":
https://www.qnap.com/i/useng/s...t/con_show.php?cid=8
Posted on: 12 March 2016 by Harry
Video Station
My Apps
Install Manually
Any good?
And it's never a bad idea to check that you are running on the latest firmware.
