HiCap Use
Posted by: Gavin Alexander on 13 March 2016
At present I have a Nac202 / Nap200 / Flatcap2x LP12 / Lingo3 & stageline. I can afford one hicap at present, should I use it to power the stageline or the pre amp ? I'm not sure what would give the biggest benefit. Any one on the forum went for a similar upgrade
Posted on: 13 March 2016 by Richard Dane
Gavin, is the LP12 your only source?  If so, then worth trying out each option.  I would put your FC2x towards the second one...
Posted on: 13 March 2016 by Gavin Alexander
Sorry Richard forgot to mention I also have a Linn Majik DS.
Posted on: 15 March 2016 by Gavin Alexander
Just to update you, got my HiCap today tried on the stage line for a couple of hours (after warming it up) and then with the pre amp. Pre amp wins, now to save up the pennies for one for the stage line.
Posted on: 15 March 2016 by hungryhalibut
Try to get hold of a napsc for the 202 before you do anything else.
Posted on: 15 March 2016 by Reinibert
... and a powerline for the napsc ...
Posted on: 16 March 2016 by Gavin B
Did you trade the Flatcap in? If not, can you put that on the Stageline?
Posted on: 16 March 2016 by Gavin Alexander
Cheers HiCap is on the pre amo, and the Flatcap is on the Stageline
That of course should be pre amp I will try the suggestion of the napsc on the stageline, presently it's powering my head amp.
Posted on: 16 March 2016 by benjy
Almost the identical system to mine,except I already have a hicap dr on the pre-amp and lp-12 has lingo2. Also a just resuscitated tandberg tcd-340 cassette deck. My other source cd5 (cannot add power supply- might be a 5x). Speakers are harbeth m30.1. What are your speakers? My system is on a quadraspire svt rack and wall mounted tt shelf. Unable to experiment with the wiring (due to disability) the hicap has always been on the pre-amp and the fc on (come to think of it - might be a pre-fix , not stageline)
HH-
Can you tell what adding just a napsc would do to the sq? Or would looking for a 282 make more sense (I don't want to hijack this thread however)
Hi Benjy,
Complete system is LP12 / Ekos 2 / Dynavector 10x5 / Stageline /Lingo 3 / Majik DS / Nac 202/Nap 200 / HiCap / Headline +Napsc / Proac D18's bi-wired with Chord Carnival Silver Screen cables.
As I don't use the Headline very often, I'm going to take the advice and add it to the Nac 202 as well and listen to what difference it will make.
benjy posted:
HH-
Perhaps some of the more informed users might be able to answer that Benjy
Thnx- I didn't realize you already have a napsc- I never had one and did not even know you could use it on a headline.Btw my lp 12has ittok arm and lyra cartridge,speaker cable is naca 5- but still pretty similar system. My "custom stands" for the speakers are iron folding bookcases from container store- just the right height and weighed down with heavy books
Hungryhalibut posted:
Moved the napsc from the headline to the 202, it has made a difference not dramatic but I can hear a difference in timing and depth.
Reinibert posted:
All the kit is on a dedicated separate spur, what powerline would you recommend ? Naim I guess or are there others that you have tried.
