Editing metadata for.dsf files...
Posted by: Jason on 13 March 2016
I have been trying to edit the metadata for a few hi-definition (.dsf) music files i have downloaded, but have not been able to do this using dbPoweramp. Does anyone know if it is possible to use dbPoweramp to change the metadata or is it just not compatible with .dsf? Normally, I can right click on a file (such as .wav or.flac) and select "Edit I.D Tag" which then opens a screen allowing me to adjust the metadata. Unfortunately I don't get this option with a .dsf file. Any Ideas on how I may be able to access the metadata, or what program may do?? Thanks.
