Nac 32-- Should I remove my tape buffer boards?
Posted by: mikeybaby on 15 March 2016
Currently using an NAC 32 with a Hicap. I have just removed my phono boards and notice a huge improvement in all areas. Should I remove the tape buffer boards also?
Posted on: 15 March 2016 by Jo Sharp
If they aren't used, then give it a go.  If you find an improvement, all good.  If not, you can put them back in.
Posted on: 15 March 2016 by mikeybaby
The sound is more detailed with the boards in. Thanks!
Posted on: 17 March 2016 by mikeybaby
But what is the general opinion?
Posted on: 17 March 2016 by Richard Dane
I think they should be left in.
I think they sound better in. Thanks Richard.
