If it sounds broken......
Posted by: Polarbear on 16 March 2016
...... it probably is!
A couple of weeks ago I thought my system had started to sound a bit thin and tinny, especially on CD replay. Never really thought enough about it to check it out.
Today I picked up a new Interconnect from Peter for my CD555. I wanted to hear the new cable in my system after hearing it at Whittlebury in one of the Cymbiosis rooms. I went to disconnect the HI-line and the back half was hanging off. Thought to myself that it didn't look good and put the new cable on the CD555 and wow what a difference. Put the Hi-line on the NAT 01 and bloody hell does it sound bad. The NAT 01 had a bog standard cable on it and I thought I would upgrade it to the cable from the CD555 but no, it wasn't a step backwards it was a step back to an old transistor radio!
Tomorrow, Karens taking the hi-line into Peters to see what the heck has happened, until then its back to the bog standard cable.
Moto of the story is that if it sounds broken then it probably is. I should have checked it out rather than thinking it just sounds a bit off!
