ittock swings to right
Posted by: mrflange on 19 March 2016
For some reason  when lifting tonearm it swings to right  checked lp12 to see if it's level and no problem there
Posted on: 19 March 2016 by badlands
It's called anti-skate.
Posted on: 19 March 2016 by varyat
As Badlands has replied,your bias, or anti-skate, may be off. If you are not comfortable recalibrating the arm have a dealer do it for you. The usual starting point is the same value as your VTF, or the tracking force set for your cartridge. Check this first. If the values are close, and your arm is still swinging back to the right you may need the arm serviced. Good luck!
ATB,
Mark
Posted on: 19 March 2016 by Mike1380
Also worth noting...
The arm-lift mechanism on an Ittok has a rubberised surface to it to stop the arm moving from side to side. Over time this rubber collects dirt, grime and dust and becomes slick. If you 'roughen it up' by way of a wipe with some emery paper, or run the edge of your thumbnail across it, you can get rid of this layer of dirt and re-introduce the grippy nature of the rubber layer.
It's there to counter the anti-sikating force when the arm is raised or lowered. My bet is that your anti-skate is set OK but the rubber layer is not countering it.
Easy to check, 10 seconds to fix if I'm right.
Worked well on mine and my dad's Ittok players.
Best of luck
Mike
I bet Mike is on to something here- good call!
Posted on: 20 March 2016 by mrflange
Mike1380 posted: spot on, now fine thank you
Best of luck
Mike
