nait 2 - logo light defect
Posted by: Tobias Fricker on 21 March 2016
hello,
I have a very nice Nait2 CB
since today the logo light turns from green light to no light.
I mean about 5min no light - and 1 min the logo light is working
... anybody knows this problem???
It sounds like the Led modules behind the logo / text are failing. It's fairly common.
Moderated post: Lewis, I have edited your post to ensure it complies with forum rules.
Ps. They are also wired accordingly to illuminate the text partly and the logo fully hence the wiring.
it`s a bit strange because sometimes it`s working - and sometimes not.
I would expect if the led is defect, there will be no light anymore.
I would not expect an LED to go on/off, its all or nothing IME. The LED is in series with a resistor to set its brightness. An on/off LED indicates an intermittent break in its circuit, maybe a bad solder joint or a cracked resistor. It should be easy to find & fix, have you contacted a Naim service dealer ?,
I had the same problem with a CB Nait 2 that I had a while back (now back in the fold...). Sent it off to Darran at Class A and it was replaced at the same time that he serviced it. I believe the LED unit was £30 but this was sometime ago. Give Darran a call. It may well be worth servicing it at the same time and then you will be good for 10+ years.
Welcome to the sweet sound of Nait 2 ownership. Enjoy.
Neil
last service was 2002
maybe service it`s worth anyway
159GBP
I think about
thanks
Lewis posted:It sounds like the Led modules behind the logo / text are failing. It's fairly common.
No problem.
