Upgrade direction
Posted by: Lee Piercy on 22 March 2016
evening enlightened ones.
I have enjoyed the Dac V1 Nap 100 combo hugely. I added the highline with great results and Roon via a headless Mac mini has been a joy, the music poring out of the sublime eclipse TD510z is fantastic.  However upgradeitis has set in and I'm thinking of swapping for a Superuniti which would have the added benefit of bringing the turntable out of retirement from the loft and only one box too but, I would loose Roon.
I am looking at new with a trade in of my old kit. Is there anything else I should consider, possibly keeping the V1 for Dac duties?
thanks in advance��
Posted on: 22 March 2016 by Sloop John B
You could always go Mac mini optically into SuperUniti to keep Roon.
You will need a phono stage to have vinyl again though.
my advice (as a Superuniti owner) would be to get a Naim amp like a Nait XS or SuperNait keeping your DAC V 1 and the flexibility it offers.
There is a lot of (potential) redundancy when you have amplifier and DAC in the one box.
SJB
Posted on: 22 March 2016 by J Saville
Instead of the Superuniti, what about a 272 and keep the 100? Costs about the same as a Superuniti but has major upgrade potential.
Posted on: 22 March 2016 by CharlieP
Presumably you are using you computer USB into the DAC V1.  If you trade the V1 for something that lacks USB input, you could get a USB to SPDIF converter and use a coax cable (or optical), yes?
Posted on: 22 March 2016 by Bert Schurink
I would also suggest you go for the 272 and take benefit of the bigger upgrade potential.
Posted on: 25 March 2016 by Lee Piercy
Thanks for the suggestions, I am now leaning towards the supernait 2 and keeping the V1. I may even purchase the Hicap while I'm at it as it will look nice sat next to the V1 ;-)
How does the V1 connect to the supernait? Can I re use my Hiline?
Lee
Posted on: 25 March 2016 by Mayor West
Hi Lee. SN2 is great. However as good a source as the DAC-V1 is, I think your money may be better spent improving this rather than adding a Hi-cap to the SN2.
Posted on: 25 March 2016 by Jude2012
Sloop John B posted:
SJB
+1, depending on ultimate system aims the SN2 or a pre power (at least 202) would be what I would consider.
IME, the Mac mini, V1 into 282/200 with revealing speakers, really shows the V1s potential.
Not sure whether the Hi-line would need a different pin configuration to connect to a Nait or NAC?  Or whether it's possible for Naim to change an existing Hi-line? https://www.naimaudio.com/site...cation%20Rev%20J.pdf
