In-Line Attenuators
Posted by: Got Hi-Fi? on 24 March 2016
I am just wondering if anyone here has tried any attenuators on naim gear? In particular, between the pre-amp and power amp (or power supply). In my case it would be due to the high gain of the system and my need to often listen at low levels.
Are there even any available that work with naim gear, or do custom cables have to be used? (the less changes I would have to make the better as I want SQ affected as little as possible) I have seen the ones from Rothwell, but they are only RCA and XLR.
