compilation albums solution
Posted by: singgs on 28 March 2016
I was trying to get my (self-compiled) compilation albums to show as ONE single album via the upnp section of my naim app so that I could add it to the play queue on the naim app en masse. The album part of the naim app shows the compilation but it only allows the user to add one track at a time to the play queue.
I looked on this forum and saw similar queries but no solution so here's mine:
I'm using a naim uniti with a vortexbox server as upnp and I use dbpoweramp as my software for adding id tags to flac (or alac) files
I have a few thousand old soul 7" singles ripped to my vortexbox and I generally compiled these as CD length compilations so there are approx 90 'soul singles' compilations on the VB. Noting that  the play queue on the Uniti 2 allows one to add 500 tracks, I then merged the CD length compilations into approx 500 track compilations on the VB
The solution is to edit the ID tag in dbpoweramp and unify the GENRE for the compilation to match the name of the compilation itself. The Naim app will then show this compilation in the genre section of it's upnp music section and it will add the whole compilation as a single item to the play queue. Since the artist/track names have not been altered, they show up as normal. Being adventurous(!), I noticed that the naim app allows one to shuffle the queue which is a nice approach as the soul 7's have been added over many years
I'm not sure if I've explained this too well but hope it helps , because it was driving me mad!
Best
Paul
Posted on: 28 March 2016 by Adam Zielinski
Clever - so essentially you've created a specific GENRE for those albums, and then play the entire GENRE or shuffle it.
I like that solution.
Posted on: 28 March 2016 by singgs
Thanks Adam
Exactly.  500 songs at a time.
I was getting so frustrated adding 1 track at a time to the play queue so I tried this because I noticed the naim app recognises 'genre'. I was pleasantly surprised when it worked - it works with dbpoweramp software, not sure if other software will do this.
Listening to my old soul singles  on the Uniti 2 as we speak...in lossless format(although this is somewhat limited by the source material!)
