One of the remote controls for our garage door has stopped working. It's the 'spare', and is only occasionally used by SWMBO when I am out with the car on my own. My first reaction was change the battery (it takes a CR2032 flat lithium battery - one of the little disc thingies). Didn't cure the problem, so put the old battery back in and then the little red light on the remote was working again, but still no joy with opening/closing the garage door. I looked through the manual to see if I could reset the remote, assuming that for some reason it wasn't transmitting the same frequency as before. Alas, the manual referred to a remote which didn't resemble ours at all!
SWMBO rang the garage door company today while I was out, and was told 'oh, you must have been handling the battery incorrectly, you must hold it with tissue paper and not touch it with your fingers', and then told her that I could bring it in and they would try to fix it, but if they couldn't it would cost £50 for a replacement! (only 3 years old).
Obviously the comment re battery handling is complete boll**ks, but £50 for a little keyring fob remote?
Posted on: 30 March 2016 by Bruce Woodhouse
I have a Hormann auto garage door The detailed instructions include a method of the base unit 're-learning' the remotes frequencies so that the keypad and remotes work fine. I have had to do that after a sustained power cut I recall
It may be because of a weak battery your remote handset has defaulted to another channel and become invisible perhaps? I'd be surprised if your system did not have the same option of resetting-from the base unit rather than the remote itself? Just a thought.
Bruce
Posted on: 30 March 2016 by james n
You're right Bruce - most remote's work on the same system the older car alarms did with a rolling code arrangement between the fob and controller and can go out of sync. Saying that when one of our garage remotes broke (i stood on it !), it was about £30 to replace and a royal PIA to find the right one to match the controller.
Posted on: 30 March 2016 by Dungassin
I would do and internet search if I knew the actual model of remote. It doesn't have any serial numbers etc on it. I've tried changing the battery - didn't cure the problem. I would be surprised it that were the problem as I don't think the remote's been used more than once a month since we've had it. My remote is used daily, but then remember that SWMBO is a non-driver. Still annoyed that the company tried to bullshit SWMBO with nonsense about not touching the battery with your fingers. The door was supplied by a Derby company, and carries their brandname. Looks like I'll have to traipse across to Derby and see if they can reset it or otherwise cure the problem.
Of course, if I knew the model number of the remote, if it wasn't one of those using a rolling code, then I could just purchase a cloning remote.
Perhaps that's the problem - maybe multiple remote controls are not compatible with rolling codes? But if so, why has it taken 3 years for a problem to appear? Or can the base unit cope with 2 or more remotes each using a different frequency? Just wish the manual was more informative.
Well, I called on the company this afternoon. Apparently the bit about handling batteries was because some morons do it with greasy hands, and they've had problems with this in the past. My supplied documents were from the manufacturer at a time when they were changing from one remote to another. They agreed that it was probably just the remote needing to be re-registered with the base unit and they gave me a photocopy of the procedure for adding a remote to the existing one. Got home and tried it - to the letter - no joy. So they're contacting the manufacturer to see how long the warranty is on the remotes (sigh)
