MinimServer "properties"?
Posted by: blownaway on 02 April 2016
Earlier Eloise said.....
"With MinimServer there is no need to manually tag things - if you go into the MinimServer properties, in the list of "index tags" add #AudioQuality, #AudioData, (you need to make sure you continue a comma separated list so each item except the last is followed by a comma and you can add either or both) - after a rescan you will then find new indexes to browse."
Where do you see properties in the MinimServer software. When I hope the software all I see is the "MinimServer Status Page", no properties. What am I missing? I don't have my 272 plugged in (waiting on speaker cable).
I was hoping to set up tagging this way for my HD music.
Thanks!
