DAC V-1 "cannot reclock" with Rega Apollo or Airport Express
Posted by: ngarritson on 02 April 2016
Hi,
I have a DAC V-1 that I have been using at work. It works flawlessly with my MacBook Pro as the input source via asynchronous USB. I brought it home to try it out in my main system with a Rega Apollo R cd player and the Apple Airport Express for streaming. The V-1 doesn't seem to work for either source. I connected them both to the V-1 using optical cables. In both cases I get an error message saying "cannot reclock". How do I fix this?
At this point I am convinced the problem is with the V-1 because I have been running both input sources into a standard nDac via the same optical cables without any problems.
Thanks for any input you can provide.
