nac82 output from a source (e.g. CD or Tuner) to Tape,VCR or Aux connection
Posted by: Peter1999 on 04 April 2016
Trying and failing to switch/connect the output of an NDX5-XS via an input connection (typically the "Tuner" input ) on my nac82 Preamplifier (circa 1999 issue) to a record output connection (typically such as CD,VCR and Aux on Outputs 4,5 and 6 respectively) to which I am connecting a headphone amp .
As per the Owners Manual I depress the "record button" on the source (CD or Tuner) device. The depressed button's lamp glows dimly and there is no effect when also depressing the "record button" on the selected output device connection (Tape, VCR or Aux) to record, ie the output device button does not glow nor is there a discernible output to the headphone amp).
Connecting the NDX5-XS using the same cable directly to headphone amp works fine (so the cable is presumably correctly configured). The cable consists of the Naim plug wired as per the diagram for nac82Outputs 4, 5 and 6 in the Owners Manual and terminates in two phono plugs for connecting to the headphone amp.
I have checked that the Record-Lock is not switched on and that the Mute button is off.
Query : am I operating the nac82 Preamplifier incorrectly, does my nac82 have a switch problem or could there be some form of incompatibility problem?
Any advice on this would be very welcome !
