Naim CD5i - CD Drawer Problem
Posted by: aj_vader on 04 April 2016
Hello,
I have the Naim CD5and I discovered that some of the plastic that holds the CD in place has come away, It came off yesterday when I took the magnet off to place a CD onto the Drawer. I should say the player runs fine and still sounds as beautiful as the day I bought it (if not more beautiful now), although I am worried that I could be causing further damage by playing it, so I haven't played any more since I discovered the problem.
Naim CD5i 2
Naim CD5i
Naim CD5i
Naim CD5i
Should I get this repaired?
Thanks in Advance,
Andy
Posted on: 04 April 2016 by Damo66
I would most certainly get a new laser mechanism fitted. You wouldn't want more bits of what's left of yours flying off and into your machine while a disc is playing.
I had a new laser fitted to my CD5i around 18 months ago....wasn't too expensive.
Posted on: 04 April 2016 by aj_vader
Why would I want to get a new laser fitted? Mine works fine.
IIRC the replacement mech and laser I had fitted to mine included the bit that is broken on yours.
Apologies for trying to be helpful.... I won't bother again.
Posted on: 04 April 2016 by Harry
Well, quite. On both counts.
Sorry I just thought that you thought my laser wasn't working. I appreciate the help, but do I really need the whole thing replacing? I thought I could just replace the damaged section.
The damage is part of the mechanism which includes the laser. The good news is that Naim can service and repair your CDP so you don't have to bin it.
Posted on: 04 April 2016 by David Hendon
I suggest you ring Naim support and tell them that you have posted these photos. They will look and advise you what needs to happen (but if it still plays fine then personally I wouldn't worry about it).
best
Thanks for the advice people.
Posted on: 04 April 2016 by sheffieldgraham
how old is your CD player.
Have a look at this. Under certain circumstances you have a some  protection from defective goods for 6 years.
http://www.dailymail.co.uk/new...arantee-expires.html
I bought it in 2009 so its out of any warranty.
