Cables...Only Naim ? Or is that "old" ?
Posted by: JF Lux on 05 April 2016
Hi - I've tried to find a definitive answer in the forum and across internet searches but cannot reach a clear, definitive answer. Maybe the reason is that things have evolved and older info is no longer valid?
Is it required (as opposed to preferred) to use Naim speaker cable? And if yes, does it need to be a certain length?
I have seen articles saying use of non-Naim cable invalidates warranty; Naim cable is an integral part of the system; swinging to non-Naim cable is perfectly acceptable and can be used without any issues and so on...
I am not looking for advice on alternatives. Just need to know if should be getting at least 6 meters of Naim speaker cable right now or I have nothing to worry about for a while (eg. warranty is retained and something isn't going to go bang when I pick up the new system next week...! )
And if anyone wants to extend an answer to interconnects feel free.
thanks.
