Mullet Source of the Century?
Posted by: Michael Mccullough on 08 April 2016
So, I blew my budget on a Demo RP6 with new Exact. Limited funds moved me to purchase an Original Sony PS to use as a CD stopgap after hearing about it from Art Dudley and John DeVore.
That little bugger has some boogie in it. Doesn't "sound" great but it does notes and beats better than 95% of the CD players I've heard.
Best $32 I've spent.
Posted on: 08 April 2016 by wenger2015
Theirs nothing wrong with being a member of the mullet club
Posted on: 08 April 2016 by Adam Zielinski
Good deck - RP6 / Eact II! Just make sure you get one of the Rega phonostages - even the Fono MM will make it sing, whilst Aria takes it to heaven
Posted on: 08 April 2016 by Maxi Me
Rotel RCD965BX into 252/300 into Ruark Prelude II's. Got to be 'mohican' of the year?
Sounds fabulous to me!
Ok - Oppo 105D into 282/SCDR/250DR
Posted on: 08 April 2016 by Michael Mccullough
Adam Zielinski posted:
Will be using Stageline/Flatcap. Moving in a few weeks so it's still in the box.
Michael Mccullough posted:
Have not heard this combo, but should be good!
One piece of advice from a fellow Rega user - you know that little 'plug-into-the-wall' power supply' that comes with RP6? Keep it on a separate mains spur from your Naim gear.
Thanks for the tip.
