Is it me.....
Posted by: The Strat (Fender) on 09 April 2016
......but when the atmosphere is damp you get more static with vinyl?
Posted on: 09 April 2016 by hungryhalibut
It's usually the other way round.
Posted on: 09 April 2016 by Chris Dolan
It's you
Posted on: 09 April 2016 by The Strat (Fender)
Okay I'll have a glass of Malbec - that should fix it!
Posted on: 09 April 2016 by ken c
The Strat (Fender) posted:
good choice!!! which one?
enjoy...
ken
This is a nice glass
Perhaps if you didn't slop it all over your records you'd have less surface noise. I'm not so keen on Malbec, it's generally a bit heavy.
Posted on: 09 April 2016 by Adam Zielinski
I recommed a good bottle of Pino Noir from North Italy.
Takes away all the static...
Parra Alta from Argentina.
A bottle from a small`Katarzyna' wineyard in Bulgaria
Posted on: 09 April 2016 by Allante93
I know a gentleman, that has an S1 Pre and an analog TT, he prefers his CD555.
But Once Again, The Analog TT, The Digital CD, and Digital Streaming Depending on Music and Mood!
Choice is a Good Thing! The Mechanical TT is hard to beat, its emulates the Instruments best, however the needle itself presents a bag full of negatives.
Each format has it's advantages and disadvantages!
Oh, .....but when the atmosphere is damp you get more static with vinyl!!
Well take the good with the bad!
And enjoy your Music and Wine!
just my two cents!
Allante93
Posted on: 09 April 2016 by ChrisSU
Chris Dolan posted:
It's a crap glass, there's no wine in it!
Posted on: 09 April 2016 by wenger2015
Best way to stop static is not to come your hair whilst putting on a record
And on a serious note - the best gadget dealing with electrostatic energy I've found is a contraption called Zerostat 3 Milty.
Got it as a gift from my Naim dealer (otherwise he knew I would never even contemplate using it) - absolutely brilliant! Works wonders on a CD too.
Adam Zielinski posted:
Not heard of that...but if it works I need to investigate
Available from Amazon UK - this way if you don't like it can always go back
wenger2015 posted:
I take it you've seen the film, 'There's Something About Mary' then?
ChrisSU posted:
wenger2015 posted:
It's a classic
Thanks Adam
coincidentally -- i was having an Alta Vista this evening...
enjoy...
ken
ChrisSU posted:
wenger2015 posted:
I read that as comb initially so it took a while to get the point
Posted on: 10 April 2016 by The Strat (Fender)
Thanks chaps for the advice. Not sure where we are with the static today - only just awoken from the Malbec induced coma.
Posted on: 10 April 2016 by Adam Zielinski
Not sure either - Pino was good last night.
However static seems to have disappeared....
Posted on: 10 April 2016 by sjbabbey
Just listened to Steely Dan's "FM" .... No static at all.
Posted on: 10 April 2016 by Wiltshireman
wenger2015 posted:
I discovered that zapping a cd improved things years ago but haven't had a gun that works for years but it did work so must get a new one. Thanks for the reminder.
