CD5 XS and HiCap
Posted by: Johnforty on 11 April 2016
Possibly silly question but if using only the spdif output would my CD5 XS still benefit from an external psu? Reference manual in 12.3 states 'The CD5 XS output stage can be upgraded . . . addition of an external Flatcap or Hi-Cap . . . .' . Perhaps this suggests that such an addition would only improve the analogue and not improve the spdif output. Does the spdif/analogue switch actually switch off the analogue section or just divert the digital signal away from it and simply present it on the socket leaving the anologue section still powered-up?  Thanks, J
Posted on: 11 April 2016 by hungryhalibut
No, there would be no benefit.
Posted on: 11 April 2016 by Johnforty
Thanks for that - saved me cost of another Hi-Cap or a change to Supercap. However, do you, or anyone, know the function of the spdif/analogue switch as in my original post? Curious that's all. j
Posted on: 11 April 2016 by Michael Mccullough
Johnforty posted:
From the owners manual
The CD5 XS can provide either analogue or S/PDIF format
digital signal output. The analogue output is carried by
either a single DIN socket or a pair of RCA phono sockets.
The digital output is carried by a single 75Ω BNC socket.
Digital and analogue outputs may not be used
simultaneously. Selection is achieved by using the rear
panel mounted switch. The CD5 XS must be switched off
before the output selection switch is operated. Ensure the
correct cables are connected before switching the
CD5 XS back on
Posted on: 11 April 2016 by AussieSteve
I have a Hicap on my CD5XS and it "boosts" the signal and provides a cleaner sound. HOWEVER, because of it's cost, if you plan on getting a streamer, the S/PDIF will carry the signal and the analogue side will sleep. making the Hicap a boat anchor, unless you have say a 282 preamp,    sidenote - I use 2 x Hicaps on a 282 thereby powering BOTH analogue channels and my wife and I can easily hear the benefit, regardless of what some may say. That depends on your ears foremost, so try out and play around.
Posted on: 11 April 2016 by rjstaines
Michael Mccullough posted:
CD5 XS back on
Why ?
Has anyone deliberately or accidentally changed the switch setting without power cycling the player?
When I wanted to do some A:B testing to listen to the difference between analogue and digital, I was tempted to just switch between the two without turning it off... but the £2245 price tag held me back from trying this.  Sometimes I wish I was more foolhardy (or £ rich).
Posted on: 12 April 2016 by Johnforty
Great responses from everybody, thanks. Last post from RJS is the kind of way I think about these things. I'd still like to know/understand the actual funtionality of the switch - could be it operates a relay/s to divert the signal from the onboard DAC to the spdif socket and perhaps also switch off the internal psu section from the onboard DAC and anologue section/s. If I were designing such a device thats how I would be thinking (Loooong time ago I used to build my own valve and transistor pre and power amps mainlly from Mullard designs et al and my own speaker designs). Anyone know were I might find a circuit diagram or service manual? I'd leave it to Naim to do any work of course! Just curiosity again! j
Posted on: 12 April 2016 by Richard Dane
John, I asked Steve Hopkins at Naim and he informed me that the CD players must be switched off when the s/pdif switch is used as it's down to software - i.e they require a power cycle.  Without this, it does not switch.
Richard (and Steve), thanks for that. All is clear now! j
