Hi Tina, take a minute to tell us what's connected to what? I ask because you can't have unity gain on a NAP150x (it's all unity gain)... do you mean the NAC202?
and where's the NAPV175 connected? ...I assume the output from the audiolab?
What you're describing sounds like an earth loop problem. The CD5i provides earthing in a Naim system. If your Audiolab is also connected to your TV, then here's the most likely source of your problem... the TV is messing with the earthing of the system. This is what I found a while ago. My answer was to insert one of those earth loop isolating thingys between the TV audio and the A/V processor.
My best advice would be talk to your (friendly?) Naim dealer... or watch out on this forum for more advice... the good news is your problem IS solvable for not much money
