iTunes library management
Posted by: bluesbreaker on 19 April 2016
I have around 765 albums in iTunes on an external HDD and I have been backing up these using SuperDuper. I have also switched the HDD I've used for my library in playback on a couple of computers. Anyway, I have noticed a small number of albums don't appear on my "Main Music" folder but are in my "iTunes Media" folder.
This doesn't make any difference when I play music through iTunes but some albums didn't appear in Roon, thought a bit of fiddling around and selecting both folders for Roon to use solved this.
I've always found iTunes file management to be confusing and I'm not sure how this has come about but I'm wondering if I should use the option to consolidate all my files in iTunes. I believe this would copy everything into the iTunes Media folder thus giving me a massive library. Should I
a) Do this and then once everything is in "iTunes Media" folder just delete everything from the "Main Music" folder?
b) Drag my files from the iTunes media folder into the Main Music folder
c) Do nothing
Seems odd that this has happened and I'm not sure why. I have the option to copy everything to the iTunes Media folder when adding to Library ticked but clearly that hasn't happened and folders have been sent to either one or the other of these folders.
Thanks for your help
Posted on: 19 April 2016 by Bart
iTunes definitely manages its "library" in a somewhat unique way.  I have the luxury of not using iTunes for anything related to my home hi fi.  I still have an iTunes library, but use it solely to maintain my iTunes Match library, and it contains all lossy files.
If you want to have a single library that is the target library of both iTunes AND another player, you may always have some gripes.
How do you play files at home?
Posted on: 19 April 2016 by bluesbreaker
Hi. I have a macbookpro with AIFF files on an external HDD into an amplifier with integrated DAC. Library management was always in iTunes and I have used several players including A+, Amarra and now Roon. Maybe I just need to get my teeth into Roon which is the closest I've got to being happy with a player
Posted on: 19 April 2016 by Adam Zielinski
I would say - forget iTunes and it's weird way of handling the library. I tried it in so many configurations - still ends up in a mess (we have only Macs at home, so I'm pretty good at this and still couldn't get my head around the 'logic' of this).
As soon as I installed my NAS, iTunes is only used for syncing lossy files to an iPhone.
Adam
Posted on: 19 April 2016 by Borders Nick
I have everything on ITunes (mainly for historical reasons) and my filing was a bit messy when I started upnp streaming about a year ago.  The "consolidate" option certainly sorted things out for me, automatically putting everything into the iTunes media music folder.  I then was able to delete all the left-over duplicate (& now empty I seem to recall) artist & album folders from the old "messy" file structure.
Posted on: 19 April 2016 by dayjay
  Adam Zielinski posted:
Adam
+1, its the devil's work!   I won't have it active on any of my systems and I don't like the way it interferes with my files and the weaves itself into the system.  When I use Audirvana I use its native library rather than ITunes mode which sounds better anyway.
Posted on: 19 April 2016 by Mike-B
dayjay posted:
Another BIG PLUS ONE  .............  I thought it was me being a behind the times ol' fart & anti-social.    That all might well be true,  but its gratifying to read that others agree with me about iToons
All righty and thank you all. I would be quite prepared to ditch it, but TBH I'm so inexperienced I thought I had to use it. Can I just copy all the files from my iTunes music library to a folder in my HDD and expect Roon or whatever to pick up all the metadata and tags etc without problems?
Mind you, BordersNick, if you found the solution easy after consolidation I just might give that a go first. It's a painless trial
Posted on: 28 April 2016 by magicaxeman
I on the other hand run iTunes as not only my primary library resource but also as the main server for all my media including music.
I find it easy to use and my nas drives all have iTunes server built in so no issues there.
The main thing is on how you organise your files before putting them into iTunes.
My flacs are converted to ALAC, then into mp3 tag where I sort out the metadata and make sure its correct, I also resize my album art work (photoshop) and then replace the embedded album art work.
Once all this is done the original flags are sent to two separate external drives for archiving, the finished and sorted ALAC's are imported into iTunes.
As said my iTunes media library is held on my primary nas and played from there via my different media devices ( MBP, iPad,Revo supper connect)
24bit flacs are stored on a separate nas and served to the same devices via DNLA.
The main thing here is not mixing and matching when it comes to storing/servers for your media, I had endless nightmares using twonky and other servers as well as iTunes and lots of confusion over what was where.
By unifying and using just the one main library things are simplified and being anal over metadata tagging means the files are as they should be before getting stored so no issues there.
But as said if you look logically at what you need and set it up simply you can get good results.
The main limitations are iTunes still not working with flac's and the resolution limits on ALAC
Posted on: 29 April 2016 by james n
Everyone has a different way of managing their music library. Can't say i've had problems with iTunes myself- i find it a useful way to manage my music and it works well for me and the various music playback devices that use it. As Nick suggests, using the consolidate option organises the library into one folder and this is the way i use it with my iTunes music folder held on an external NAS. I can't really see how this would be confusing to anyone as the directory structure is very simple. A bit of housekeeping when importing makes sure that artwork and tagging is correct.
My Sonos system has no problems using the iTunes library and the Melco in my main system and my Sony portable (and a couple of USB disks) are synced with the library on the NAS with cloning software.
Posted on: 01 May 2016 by Paul Quigley ie
Any other ways to get  music on to Apple products without using iTunes?
