Upgraditis strikes . . .
Posted by: Mike Woodcock on 19 April 2016
A month or two ago, I spent an unplanned afternoon in my local dealer and did an extended comparison of a 272/200 to my exiting UQ2/100.  Unfortunately, I haven't been able to move on since.  I have deliberated various upgrade routes, but I think, given budget and space (ie no of boxes) where I have landed is a 272/250 ultimate setup, possibly with the addition of power supplies at a point to be determined in the long distant future. I would add the 272 now and the 250 as funds allow.
I briefly considered the merits of a separate streamer/pre/power combination but couldn't see an easy route to get there and I wasn't sure that for the separates costing a reasonably similar amount (NDX/202/200) would give a justifiable improvement.
Am I missing something here and is there any other route I should consider?
(PS I know my speakers will need upgrading also to match the 250 . . .  Small steps!)
Posted on: 19 April 2016 by ChrisSU
Hi Mike, I went through a similar decision making process last year and eventually decided on the separate streamer route. For the same price as a 272/XPS/250, I went for NDX/282/200, which to my ears, sounded better, despite the inferior power amp....bearing in mind that my Kudos X2 speakers are not hard to drive.
My upgrade path was: add 200DR to Superuniti, then add NDX, then swap Superuniti for 282. Stage 1 and 2 complete, stage 3 to follow later this year. I guess you could follow a similar path, except that you could keep your 100 and start with the source upgrade. Alternatively NDX/Supernait could be worth considering.
In my opinion, the 272 needs an XPS to compete with these systems, but if you choose this route, you'll still end up with a nice system. Hopefully, you'll enjoy making your dealer earn his money by letting you take your time and listen to some of these options.
Posted on: 19 April 2016 by hungryhalibut
If you wanted to go the NDX route, you could get that, and a preamp - either the 202 or the 282 - to go with your 100. You could get a used NDX and 202 for about the cost of a new 272, though bear in mind that the 272 is better as a preamp than the 202, so the real comparison is a 282 and NDX, which costs a lot more than a 272, even used. But of course the 100 cannot power the preamp, you'd need a Hicap as well.
I upgraded from a SuperUniti last year and considered two options - 272/250 and NDX/SN. I didn't bother listening to them, or indeed seeking opinions from anyone. They are both jolly good and ultimately I don't care which sounds best. I bought the 272/250 because:
  • it only needs one power supply to upgrade it
  • it only ever needs two plugs, and my spur has only two sockets
  • you cannot use a Hiline with it
  • the 250 has more welly than the power amp in the Supernait
  • the 272 has the same lovely volume control as the SuperUniti
  • the 272 isn't covered in buttons I don't need
  • I just like the idea of a streaming preamp
So that was my logic, based on logistics and instinct. You can fret over these decisions for ages, and each person will have a different opinion; just go with whichever feels right to you.
Posted on: 19 April 2016 by rjstaines
I can recommend the 272 - I have one.  I can recommend the 250DR - I've heard one in a comparison dem, but don't have one.
I've had an NDX, but never had a SN.   Bottom line would be the power and control the 250DR gives you beats anything I've heard below the NAP300.  The 250DR is offered as a serious amplifier to customers wanting a very high quality system, like you.
It's got to be a no-brainer to opt for the 272 /250DR, as far as I can see (and hear).
HH's 7 selection criteria may not all align with yours or mine, but his conclusion cannot be faulted.
That's my opinion... others on this forum will disagree.
Roger
Posted on: 19 April 2016 by Mike Woodcock
Thanks all, the number of boxes is key in the decision making process . . . .
HH - what do you mean by it only needs one power supply to upgrade it? Does one of them not take an external PS?
Also - Why can't you use a Hi-Line with 272/250? how do you connect the 2 units?
Sorry if dumb questions - I'm finding my way here...
HH - ignore my post - I have now been to the NAIM website and I see that the 250 has no input for either a PS or Hi-Line!  Learning more each day!
Posted on: 19 April 2016 by Bart
Hi Mike I'll answer a little for you.  The N272 can be mated to an external power supply, but there is none for the 250 power amp.
The Hi-Line is to connect a digital source to a pre-amp, for example an NDX or cd player to a pre-amp or integrated amp; the N272 has both of those functions within the same unit.  The pre-amp part of the N272 is connected to a power amp via a SNAIC type cable.
Mike Woodcock posted:
Take action and delete is your friend....
The 272 and 250 link together with a din to xlr lead, which comes with the 250.
Posted on: 19 April 2016 by Adam Zielinski
Mike
N272 + 250DR would make for a very good combo. I would recommend that you start with that, and after some months start thinking about adding a power supply (XPS DR).
N272 + 250DR is definitely not the same as NDX / 202 / 200.
Some may disagree, but N272 purports to be a 282 / NDX in one, but it's not.
Adam
Bart posted:
Make that DIN to XLR lead . . . HH corrected. Which makes sense given he actually owns these.
