nStream to display lyrics
Posted by: keano on 19 April 2016
Will this happen in 2016?
Until then you can use the "musixmatch" app on ios or android. (unfortunately you need a login for this on android since some weeks.)
Magic 8-Ball says . . . . "it's a definite possibility."
Magic 8-Ball also says, "N-Stream no longer exists. You mean the Naim App we surmise. PS it's dark and wet in here."
gert posted:Until then you can use the "musixmatch" app on ios or android. (unfortunately you need a login for this on android since some weeks.)
Thanks.
I don't imagine this is going to happen any time soon in the Naim world. Getting the metadata is presumably going to be a web thing - Deezer does it, so maybe you should lobby Naim for that to be integrated into their streamers like Tidal and Spotify are.
I don't imagine this will happen either, we can't get something simple like Rovi to work properly, so no chance for lyrics. But why would we want lyrics anyway ??? I prefer to listen & get deep to the intricacies of the music, not read the f-f lyrics. Smacks a bit of silent movies & sing along with the ball at Saturday morning pictures - younger forum'ites will not understand that last bit.
If you want lyrics, you might look at Roon. Their latest release runs on Linux, which your Zen Vortexbox has. Have a look at their forum to see if Roon 1.2 can do what you want.
I would love to see a cd booklet instead of a review from Amazon.
Jan-Erik Nordoen posted:If you want lyrics, you might look at Roon. Their latest release runs on Linux, which your Zen Vortexbox has. Have a look at their forum to see if Roon 1.2 can do what you want.
It looks interesting.A little expensive.
