Noise from Hi Cap power supply
Posted by: orestpsychi on 30 April 2016
Bought a second hand Hi Cap power supply, after it's been on for a while the Hi Cap produces a low buzzing sound. What can I do to stop the buzzing without having to turn it off every night?
Posted on: 30 April 2016 by blythe
Turn up the music?
seriously, not much you can do except turning it off. The quality of (or rather lack of quality) mains electricity means they often hum.
Posted on: 30 April 2016 by Hal
Well not much I'm afraid. Mine is humming away too. Though I hear that hum/buzz when all is silent and I am very near to that little bugger. It is possibly due to fat toroid inside protesting the quality of juice it's fed with. My CDP outclasses hicap in the buzz dept. though
Posted on: 30 April 2016 by dayjay
My UQ2 buzzed, my SN2 buzzes and my Hicap dr buzzes, my tuner doesn't.  Just have to live with it I suspect
Posted on: 30 April 2016 by Clive B
I think transformer buzz is a characteristic of the large toroidal transformers used in Naim Audio equipment. I occasionally  experience two or more of them buzzing away in (near) harmony. Sometimes turning off and on again resolves matters - for a while.
Posted on: 30 April 2016 by Adam Zielinski
Not much - unless you sort out your mains supply (do search this forum for other threads). The noise you are most likely hearing is caused by minute voltage changes in the supply, which causes the transformer to behave in a way which you perceive as 'buzzing'.  Simon-in-Suffolk wrote a very good technical explanation on that.
Posted on: 30 April 2016 by wenger2015
Theirs only one complete solution, and its install a dedicated power supply.....it's a question of weighing up cost against annoyance of buzzing sound....
Dedicatwd power supply will help a bit. But will not solve all the problems, especially if voltage is not stable (cause of buzzing).
Posted on: 01 May 2016 by Massimo Bertola
My last HCDR purred like a happy cat, I got to like it in the end; I bought a little rubber mouse and left it close to the PSU. It seemed to work, it never stopped purring.
Posted on: 01 May 2016 by orestpsychi
Thanks for all the replies I thought it might  be a fault with the power supply, but if its an inherent problem that doesn't effect the music, I'll be happy with it.
Posted on: 01 May 2016 by Adam Zielinski
orestpsychi posted:
It's not inherent to the power supply itself. It's inherent to our rubbish mains supply
I once observed (whilst rehearsing in a studio) how much a power supply voltage can fluctuate - it went from what should be a normal 230V all the way down to 221 and up to 237. Like a yo-yo. It's amazing how much it affected the sound from our guitar amps - valve ones suffered most.
And that was in a purpose-built music studio. So image what happens in a domestic environment.
