Compilations problem
Posted by: Richard Morris on 01 May 2016
(Previous posts on this topic are closed).
As a new US (and Naim) user I'm encountering this irritating problem (compilation album shows as separate tracks) when I stream from a USB (or the download folder) in the US.
What makes it especially annoying is that when the same USB is streamed from a Mu-so the compilation is recognised and all the tracks are shown in a discrete folder.
Does that suggest the the problem is fixable on the US?
Posted on: 01 May 2016 by Adam Zielinski
It really depends on many variables. If your music is tagged correctly, you should be able to play it back in a multitude of ways.
Probably the easiest way, with a compliation album of various artists, is to go to 'Albums' on your Naim App and play it back from there.
Posted on: 01 May 2016 by Paul Quigley ie
Richard,
To have compleations appear as one album the US requires the album artist to all be the same.  So you will tag all tracks with the artist "Various Artists". Track artists can be different.  Sort of a pain but that is the way it works.
Paul
Posted on: 01 May 2016 by Richard Morris
Hi Adam, thanks for the suggestion.
However the app (iPhone or Mac) shows compilation albums as single tracks when connecting as UPnP. If I switch to USB/iPod - which is the Mu-so, then compilation albums appear as discrete folders. So I don't think it is a tagging issue.
Paul Quigley ie posted:
Richard,
Paul
Thanks. I saw that in earlier posts. My point is really - why does the US treat compilations from external sources one way and the Mu-so another?
Posted on: 01 May 2016 by Dungassin
Adam Zielinski posted:
That's the way I do it.
Richard Morris posted:
Have you cleared the app's cashe? There should be no difference (as you rightly point out) in playbacks.
Richard,
Paul
US is a server, Mu-so is a render and just presents what it is give, so another server may present data in another way. Not totally satisfactory but that is the way it is.
Posted on: 01 May 2016 by Bananahead
It's a tagging issue and the solution is as previously mentioned, tag the album artist as various artists. The USB interface simply displays folders. UPNP displays based on tags.
Posted on: 04 May 2016 by Richard Morris
If anything it's a customer satisfaction issue (see also recent firmware update post) which should have been sorted out a long time ago.
