Audirvana+ settings for SuperUniti
Posted by: ChrisByrd on 01 May 2016
I've looked at Naim's recommended settings for using A+ with the Naim DAC-V1 and wondered if these were also valid for the SuperUniti. I guess the most important is to not force upsampling in A+ and let the SU's DAC take care of this. Is this the best approach, and should I tweak any of the advanced parameters? I'm using the optical out on a MacBook Pro connected to the optical input of the SU.
Chris
