iRadio slow
Posted by: dzambolaja on 04 May 2016
My iRadio has been very slow today.  Actually for the last couple of days as well.  It takes ages to first restore history, say a minute or so, then another minute or so to start playing the selected station, then interruptions start etc.
Internet is fine, the speed is around 18Mbps, ND5XS with fixed IP wired to the gigabit switch, router is fine, all devices seeing fast internet and there have been no changes to the system setup or settings for a while.  Up to date firmware.
But from some reason iRadio is slow to browse, select stations and playback suffers interruptions.
I cannot figure out if it is to do with ND5 XS network module or of iRadio is not performing these days.
Posted on: 04 May 2016 by Mike-B
I'm the same,  its been slow for a while, it's not line speed or any of the stuff you've listed.  I've tried app reset & reinstall & nothings changed,  I'm guessing its something to do with vTuner.
Posted on: 04 May 2016 by jasons
I have had similar, and still do.
Is it with all stations you tune in to?
