NDX floating or chasis?
Posted by: Nic Chan on 07 May 2016
My NDX is connected to a supernait 2 I read the manual it said it should be putted on floating if a CD player is connected within the system (which I don't.) Does that mean I should put it in the Chasis mode?
My system: NDX + Supernait 2 + Hicap
Floating for scenarios where there is another earthed source in the system. So if the NDX is the only source or other sources do not earth the signal (fairly common), then Chassis is the right setting.
Thanks for the help!
feeling_zen posted:Floating for scenarios where there is another earthed source in the system. So if the NDX is the only source or other sources do not earth the signal (fairly common), then Chassis is the right setting.
...assuming that the Signal Ground switch on the NDX itself isn't set to "Chassis". If it is, then the SN2 switch should be set to "floating" i.e. only one component should be set to "Chassis".
sjbabbey posted:feeling_zen posted:Floating for scenarios where there is another earthed source in the system. So if the NDX is the only source or other sources do not earth the signal (fairly common), then Chassis is the right setting.
There is no such switch on the SN2. This is only done on source components with Naim since their philosophy is to earth signals at the source and and all via a single source. It is possible the original SN had such a switch since it had a DAC onboard but I've never seen the older SN.
feeling_zen posted:sjbabbey posted:feeling_zen posted:Floating for scenarios where there is another earthed source in the system. So if the NDX is the only source or other sources do not earth the signal (fairly common), then Chassis is the right setting.
You're absolutely correct. I think I need a lie down ![]()
