No album artwork on app
Posted by: Clive Johnson on 09 May 2016
Hello.
I've just bought a Mu-so Qb, and it sounds fantastic!
But I think I'm having problems with the Naim app...
I can see what song/artist is playing, and play/stop/skip forwards & backwards. But there is no artwork displayed, nor can I select songs/albums/artists to be played - I have to go back to the Apple Music app. Is this correct?
I am using Bluetooth to stream music from an iPod, which has the latest iOS. Music is copied to the iPod from a Macbook Pro using iTunes.
Many thanks
Posted on: 10 May 2016 by David Hendon
I am pretty sure that you don't get album information when you stream from an iPod. I remember being sorry about that when I bought my original Unitilite. But it didn't have Bluetooth (I used the USB port), so someone may say that I am wrong.
best
Posted on: 10 May 2016 by Adam Zielinski
The NAIM app is really designed to control playback from NAS drives onto NAIM streamers.
Music should be tagged correctly and reside in accessible folders.
Also to display the artwork, the artwork itself should be in a uniform format (jpg) and named accordingly (NAIM standard for the name is: folder).
What is happening in you case, is that when you stream music wirelessly from an iPod, it is your iPod that streams the music. Mu-so is merely a recipient of the 'stream' via Bluetooth.
So your iPod is in control.
The case you are describing has nothing to do with the NAIM app.
Posted on: 11 May 2016 by Clive Johnson
OK, thanks for the reply, much appreciated.
