Nait 5 to SONOS Connect
Posted by: Jamie Marwitz on 15 May 2016
Hello,
I want to know whether the signal out din connections (A or B, not sure the difference between them) can be sent to SONOS connect RCA inputs.  I want to get SONOS speakers but continue to use cd, vinyl.
Has anyone done this? If so, where did you purchase the cable?
thanks
Jamie
Posted on: 15 May 2016 by blythe
Yes it can be connected like this.
Speak to your Naim dealer, or do a search on-line for "5-pin DIN to RCA" leads - simply select the length you require.
Try the usual on-line auction sites they usually have them listed.
Posted on: 16 May 2016 by Huge
Note that a 5-pin DIN to RCA is a different cable from a RCA to 5-pin DIN.  They are wired differently.  Also note that there's more than one wiring used for the channels in 5 pin DIN sockets.  You either need to talk to a dealer or you need to look at the manual (or possible the back of the amp) to see which lead wiring pattern you need.
Posted on: 16 May 2016 by Jamie Marwitz
Thanks for the answer. I received the same information from David at Flashback sales. I purchased the correct cable from him and having shipped to Canada.
Jamie
Huge posted:
Jamie
