cd 5xs
Posted by: ian collinson on 16 May 2016
listen through headphones and headline,what in the best power supply to use.Any advice would be appreciated
Posted on: 16 May 2016 by hungryhalibut
Get a Supercap if you want the best.
Posted on: 16 May 2016 by Frenchnaim
Perhaps Ian means which power supply can be used to power both the CD5XS and the Headline? I may be wrong, but isn't the Flatcap XS the only option in that case?
Posted on: 16 May 2016 by French Rooster
yes, flatcap.
I don't see a reference to a CD5XS, only a shouted question as to which is the best power supply to power a Headline, the answer to which is a Supercap. As to other advice: it's good to use the normal sized font and to post hifi questions in the Hifi Corner, and of course to be clear in what one is actually asking.
Posted on: 17 May 2016 by ian collinson
Frenchnaim posted:
Hello having just jumped on the forum i wanted to get a taster of what happens on here. I did have a napsc then traded it in for a hi cap,things started to get interesting thing were there i never knew existed. Although i am very happy with  this set up,5xs headline and hi cap i just wondered what your thoughts were and if anyone had a  similar set up...........headphones i use  are akg k712
