Centre channel speaker to match Ovator S600's
Posted by: heihei on 27 June 2011
Sadly Naim don't have any plans to do a BMR centre channel to match the Ovators, which is a shame as the design would lend itself to a pretty compact package. Any thoughts as to what might match??
Posted on: 28 June 2011 by Occean
The Spendor C5e's are really neutral - may be worth a look.
Posted on: 27 July 2011 by 2roomsor1
if you have the space and the cash, what about a S600, assuming these can be purchased as a single unit?
considering (on average) 80% of a films soundtrack is through the centre channel, it is possible the most important channel in a home cinema set up?
Posted on: 28 July 2011 by DT79
As long as no-one is going to sit too far off-axis when watching films then you can leave the centre speaker out - set-up your AV processor to acknowledge that you don't have one and it will automatically mix the information into the front L&R.  With high quality Naim amplification and those Ovators, believe me it will be far far better not to have a centre speaker than to have a mismatching one.
