supernait dac & motorola pvr/dvr
Posted by: av in bc on 27 June 2011
hi there.
i'm unable to connect either the optical or coaxial digital audio output
from the tv tuner box to the supernait dac.
just getting the same noise on both. it worked fine with my denon receiver.
is this possible with the nait? is it a 5.1 encoding output that the dac can't read?
has anyone done this successfully!
supernait/motorolla dct6412 III
Posted on: 27 June 2011 by Mike-B
The SN will not take 5.1
It cuts out or has a loud hiss in the background
Don't know wot your PVR settings are,  but my guess you have a Dolby on or off somewhere
Dolby is the 5.1 culprit
Posted on: 28 June 2011 by Richard Dane
Mike's correct.  You'll need to change the digital ouput settings on your PVR to PCM/Stereo.
Posted on: 28 June 2011 by Vaughn3D
I just faced this problem when switching to Verizon Fios, I believe the tuner is a Motorolla but I'm not sure which model.  I came to find out that even when selecting stereo output, the digital output still does not downmix and can only be output as surround.  I ended up using the analog output and it sounds fine.
Posted on: 28 June 2011 by av in bc
from what i can see there is no setting for audio output.
so i will use the analog outs which sound just fine.
thanks everyone.
Posted on: 28 June 2011 by Manu
yes there is a seting on Moto boxes, worth searching, the analog output is crap.
Posted on: 30 June 2011 by av in bc
thanks Manu,
but i have searched and i can't find it.
Posted on: 01 July 2011 by Mike-B
Read or Download the   TV Guide DVR Manual
http://broadband.motorola.com/dvr/downloads/URMD2.pdf
Page 26   -   Audio Set-Up
Dolby Digital –
• ON – Turns Dolby Digital on (available only for equipment supporting Dolby Digital).
• OFF – Turns Dolby Digital off.
Posted on: 04 July 2011 by av in bc
just to wrap this up, in case someone else runs into
this problem.
can't turn off dolby.
solution was to take the optical output from the tv (fed with hdmi)
and connect that to the nait.
thanks for all the help.
