N serve not connecting
Posted by: fathings cat on 30 June 2011
Any body had any experience of nserv via iPad not working -I can open the app but nothing works and you can't play or search.
I have tried deleting the app and reinstalling but no success?
Any help appreciated.
Gary
Posted on: 30 June 2011 by garyi
Is your serve wired to a switch or the router directly?
Is your wireless network on the same subset as the wired network?
Posted on: 30 June 2011 by KRM
Have you got any files with a / in them? A friend of mine couldn't get nServe to work for a month for that reason. He just got the "loading" message. I think Phil Harris sorted it out for him in the end.
Hope this helps or you sort it out soon,
Keith
Posted on: 30 June 2011 by fathings cat
The serv is wired to a switch. My wireless is working fine as I still have Internet connection. I can still control the serve via my laptop which is most stange.
It's worked fine for months and I haven't done anything different -very strange?
Gary
Posted on: 30 June 2011 by Jack
Obvious question but does the Serve appear in the n-serve app on your iPad, if not, have you tried entering the IP address manually?
Quite correct Jack, no IP address was the problem - the old turn it off and turn it on again gag worked a treat.........normal service resumed.
Now listening to the excellent Ain't no saint box by John Martyn, superb....
Thanks for your help gents appreciated
Gary
