iPad and spotify
Posted by: fathings cat on 04 July 2011
Can I use spotify from my iPad. I justbtried to use the software and unable to down load. Searched apps but before purchase would like to check it works.
Any thoughts appreciated
Gary
I will probably use to listen before buying on cd or not as the case could be but will consider the premium account.
Thanks again
Gary
Playing Spotify on my PC right now, but the sound is not so good as I would like. Why can not Naim add a spotify function in the new network player, NDX? Would much rather have listened through it instead of a PC. Naim, time to develop further and get some new partners if you do not want to lose the new generation out there?
Mr Winterdäck
I have connected my Sonos system via the digital optical link to the Digital input 3 of my NDX which allows me to listen to Spotify, Napster etc through the NDX. Quality is very good.
Naim's time to show that you live up to your high standards!!
Where is your response, Richard Dane?
There is still no response from Richard Dane ...
day one...
day one...
Hi Mr. W -
I asked the same question about the NDX a month or so ago, and while a couple of forum members said "good idea", there was no comment from Richard, Adam, Dave or anyone else with close ties to Naim.
I agree that all of the Naim network players, hard disk players and all-in-ones need to support all of the fee-based streaming services (I'm using Rhapsody, but would switch to Spotify if they ever open a US service). My guess is that nothing will happen until Naim supports Airplay...then everything will happen at once.
In the meantime, I've received advice in another thread on two alternatives:
1) an iPod Touch attached to the DAC's rear USB port, and controlled via Remote from an iPad, and
2) Apple TV (future solution for when streaming services themselves support Airplay)
Maybe our best bet is 1) for now, and 2) for later?
Good luck with the "hunger strike" approach of daily bumps. I doubt it will work, but I do wish you luck! ![]()
Hook
PS - To be perfectly honest, between UPnP, iRadio and vinyl, I'm not sure where I'll find the time to listen to streaming services! So many options -- what a great problem to have! ![]()
I have a pc permanently connected to my system (naimnet/digilinx), and use my iphone and an app called 'remoteless' to wirelessly control what I am listening to. This app basically allows you to control spotify on the pc from anywhere in the house
Slightly OT but perhaps useful?
Going a bit 'off-piste'; I use www.we7.com to sample music for free.
It won't work on the iPad though, 'cos it needs 'Flash'.
John.
I think you will find if you are listening to Spotify through your ipad/pod/phone the quality is only 160kps - my understanding is you need the desktop app or a sonos/logitech to stream at 320kps.
Glad to be of help.. it does work well - has sorted my problems nicely! Enjoy!
day one...
Hi Mr. W -
Hook
Hi Hook!
I completely forgot that this is an British forum so daily bumps is probably a waste of time...
Just look how long it took for the British to leave India and then we talk about protests which was a little more than daily bumps ... Well, well you have to take the rough with the smooth....
But now to something much more important, how we get our musicsystem sound as good as possible.
I have now tried your suggestion with an iPod Touch attached to the DAC's rear USB port, and the sound surpasses all expectations so really thanks for your help! ![]()
Ps - I really prefer vinyl reproduction. So vivid and it raises a lot of good (and some bad) concert memories from the past.
Mr W
