Unwanted Playlists
Posted by: Mr Underhill on 19 May 2016
Has anyone else seen and solved this:
On my NS01 when I currently rip a CD it also creates a playlist. This cannot be deleted using the web interface.
If I connect using the client I CAN delete the unwanted playlists, but they reappear a short while later.
I am running the current firmware. The problem reared its head with the last firmware.
Thx,
M
Posted on: 19 May 2016 by ChrisSU
That sounds odd, I've never had that on my Unitiserve. Are you using the internal HDD storage?
Posted on: 20 May 2016 by Mr Underhill
Not generally, I've converted a share to a store and copied all the files onto my NAS.
M
Posted on: 06 June 2016 by Mr Underhill
Thanks to Phil:
Kicks self. There are a few albums that the NS01 has failed to rip, for these I revert to Rational Rose which has been creating an playlist M3u file. When I have copied the files up to the share the NS01 has detected and displayed these files .....now deleted.
M
