Help! Streamer only play tracks in random order!
Posted by: oldneil on 26 May 2016
Something strange happend: Suddenly NDS can only play tracks in random order (jumping from track 1 to track 9 to track 6......)
I suppose it has something to do with the app (ipad), I tried to restart but with the same results.
Thanks in advance!
Posted on: 26 May 2016 by John Willmott
Oldneil:  I had this occur once and discovered it was a self inflicted wound.  Try checking the random order icon (2 writhing snakes) on the front screen of the n-serve app.  Top right hand corner of the screen next to the reply icon.
Posted on: 26 May 2016 by ChrisSU
Sounds like you might have accidentally turned on the 'random' button. If you open a 'play queue' in full screen in the Naim app, hit the ... symbol in the top R corner, and you'll see the random (crossed arrows) symbol. Tap it, and hopefully, you'll turn it off.
....or turn it off on the remote - might be easier to find?
Posted on: 26 May 2016 by trickydickie
I expect you have accidentally enabled shuffle mode.  It's the icon with 2 intersecting lines that cross over.
Seems we all replied at once!
Posted on: 26 May 2016 by oldneil
Oh, stupid me! Of course it was easy. I just turned it off on the remote, which I rarely use, but my used it yesterday so I blame it on her!
Everything was easier in the old days when I just listened to vinyl.
Thank you all of you!
I'm not sure if random play was easier on vinyl!
