Stageline
Posted by: speedmaster on 27 May 2016
Hi,
i have just returned home after several days and found that my stageline has stopped working. The little light has gone out and no sound from he turntable. The rest of the system appears to be playing as usual. Does anyone any ideas as to the problem?
Posted on: 27 May 2016 by Belfast Taxman
Obvious perhaps but how are you powering the Stageline and is the interconnect with that power supply secure?
Posted on: 27 May 2016 by speedmaster
Hi
its being powered by the power amp and interconnects appear ok.
Posted on: 27 May 2016 by Richard Dane
Speedmaster, I'm sure you mean "powered via the pre-amp".  Anyway... please elaborate on the kit and how it's connected.
Thanks Guys,
a blown fuse was the culprit. Thanks for your input
regards
OK, did a replacement fuse fix the problem?
With the help of a knowledgable neighbour. Thanks
