Two box endgame, signing off.
Posted by: Dr_J on 27 May 2016
As some of you, HH, Chrissu et al, will recognise, I have spent a few months pondering what or how to best add to my SU/PMC 23 system, probably getting more rather than less confused by the day! My original aim was to achieve a one to three (max) box system, the lower the better. I have been fortunate to be able to home audition the NAP 200DR and CD5si as possible extensions, plus following some extensive auditioning at my helpful dealer, I have arrived at m ideal solution for the foreseeable future.
Two boxes, my SU and a NAP 250DR plus Powerlines and my PMC 23's to be fed from my existing Synology NAS(s) running MinimServer, so slightly more than 'just' two boxes......
My thanks to all who responded to what may have seemed both foolish and repetitive questions and threads, but your replies helped a lot to focus the final auditions and eliminate both the electronic and fiscally foolish.
The decider? Listening to the SU + 250DR, bi-amped(!!) fed through PL's - absolutely jaw dropping - OK then I liked it best of all I'd heard. ![]()
KR, J
